Home › Forums › General Trade Forum › Down to earth elements.. Any Ideas???
- This topic has 7 replies, 7 voices, and was last updated 16 years, 1 month ago by
whiskeyjack6058.
March 6, 2010 at 1:32 pm #53029
whiskeyjack6058
ParticipantI have managed to aquire a job load of various fan and grill elements (all above board).
They have been stored in a concrete garage in plastic storage boxes and sadly most of them are down to earth on my megger and when I run them in my workshop which is on a RCB it trips after running them for a min or so..
If I remove the earth they they run fine. I have tried hanging them up while running with the earth disconnected for maybe 30 mins or so and they are still down to earth. Think I might be flogging a dead horse here but if anyone has any ideas I would be very interested and greatfull.
Thanks,
Robert.March 6, 2010 at 2:26 pm #314133Phidom
ParticipantRe: Down to earth elements.. Any Ideas???
Try putting one or two in your own oven and heating them that way. Perhaps the dampness is in the ends near the terminals.
March 6, 2010 at 2:57 pm #314134spimps
First put them in a room for a few days with a dehumidifier then in the workshop you could connect up without earth and run for 10 minutes,then check insulation.You can connect a meter to monitor the voltage leak to earth,it will drop as the heater dries out although not all will respond favourably.
Sometimes the voltage goes up before it starts to drop.
Doubt you will get them back to as new/infinity etc though but some will recover.March 7, 2010 at 9:53 am #314135Martin
whiskeyjack6058 wrote:I have tried hanging them up while running with the earth disconnected for maybe 30 mins or so and they are still down to earth. Think I might be flogging a dead horse here
Indeed you are flogging a dead horse with the examples you gave I’m afraid. Firing them up with the earth link removed for just a few moments can often cure dampness ingress. But in the majority of the cases it doesn’t simply because they were inherently duff in the first place! 🙁
March 7, 2010 at 10:29 am #314136lee8
I bin elements with this problem, there not expensive to buy and really not worth the hassle when they fail again.
March 7, 2010 at 6:37 pm #314137spimps
Why didn’t I see that,for the bin then,which one though,are they recycled or land fill,latter probably.March 8, 2010 at 6:25 pm #314138bigchrisoioi
burn them , and claim on the insurance!!!!!
March 19, 2010 at 8:58 am #314139burns
Used one van stock (been on the van a few weeks) picked up two more and used an alternative off the van all were 3 – 4 Meg ohm and didnt get past the first 3 mins before going dead short.
Took two back and binned the rest. The oven wasnt worth any more time and decided to bin the job. The oven cost £52 off Ebay. Did get a labour charge at least but not much job satisfaction there. -
