Drain and sink unblocker in dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Drain and sink unblocker in dishwasher
  • #83547
    Lily304
    The water in my dishwasher was gathering in the sump and not draining. Long story short after cleaning the filters and getting to the little rubber back flow value with water still sitting I poured some sink and drain unblocker down to try to sort the problem. However I am now unsure if this was the right thing to do due to the toxic chemicals. I have ran two empty cycles at 70 degrees with a dishwasher tablet and some bicarb to try and rinse the residue away. Is my dishwasher still safe to use or is there anything else I can do to make it safe and rectify my mistake !!!
    #423066
    Re: Drain and sink unblocker in dishwasher
    It should be perfectly safe to use. I hope you solved the problem by using it?
    #423067
    Lily304
    No unfortunately not .. Water is still gathering in filter and sump. I think it must be a blockage in the pipe.
    #423068
    What make is your appliance? There is always water visible in the sump when the filters are removed on all dishwashers.
