Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › drain pump always running.
- This topic has 6 replies, 3 voices, and was last updated 4 years, 7 months ago by
jjimjam2.
August 21, 2021 at 11:32 am #99959
jjimjam2
ParticipantHi,
My Bosch Washer dryer (WVH28420GB Logixx 7) has developed a fault. As soon as I select any program, the drain pump starts – and never stops. If I push the start button, the selected program will start, but with the drain pump continuing to run.
There’s sometimes another noise from the control unit at the back. Perhaps a relay, furiously clicking, but not always.
Any suggestions for testing or diagnosis would be gratefully received.
thanksAugust 21, 2021 at 5:26 pm #478648electrofix
Moderatorwell the first thing with a fault like this is to trace the pump up to the control module and test the switch that turns it on. Normally a triac on the board
August 21, 2021 at 8:27 pm #478649jjimjam2
Participantok thanks. I’ve found that and it looks like a relay. 899-1C-F-C 9V. And has no resistance on the coil. I can’t find one for sale anywhere, is there any hope?
August 21, 2021 at 8:53 pm #478650electrofix
Moderatorpost a pic of the relay
you may have to post pic on another site and post a public link
August 21, 2021 at 9:23 pm #478651jjimjam2
ParticipantIt’s one of these. (but mine has a white box and 9V, SPDT)
https://www.mouser.co.uk/ProductDetail/Song-Chuan/899-1C-F-C-12VDC?qs=ODlIKnK5hgdqBHS0PZlyRg{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3D{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}3DThis one looks very similar, but I should study the details closer.
https://www.mouser.co.uk/new/song-chuan/song-chuan-215h-relay/
Only in stock at 12V and ‘normally open’. I can swap it with another on the board.I’ll have a think about it. My wife’s already hinting that I should go to the launderette.
August 21, 2021 at 10:00 pm #478652electrofix
Moderatorthese relays are fairly univeral
https://www.ebay.co.uk/itm/271897325453?hash=item3f4e57ef8d:g:5XgAAOSw5ZBWMQc~
as long as size and coil is ok you will be fine. they are 10A but the pump is pulling less than an amp
the only thing that worries me here is the pump is running, which means the contacts have to be welded. Seems odd to have no coil as well
September 30, 2021 at 7:17 pm #478653andyjawa
ParticipantCould be a melted solenoid water inlet valve coil.
