Drain pump impeller axial movement (bosch)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Drain pump impeller axial movement (bosch)
  • #86893
    iBeta
    Have a bosch dishwasher with a small plastic drain pump (part no: 00611332) which has a bayonet type fixing. Can move the impeller a few millimeters away from the motor – it feels spring loaded, but want to make sure.
    Is the movement normal?
    Thanks.
    #433305
    Re: Drain pump impeller axial movement (bosch)
    If it’s a magnetic pump there’s usually always a little bit of movement in them.
    iBeta
    Ok, thanks.
    I think I’II take it out and have a look. Maybe there is something else disrupting operation.
