Drainage problem on Zanussi
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Drainage problem on Zanussi
  • #19004
    scarty10
    Looking for some help with my washer/dryer.
    Zanussi Jet System 1600 – WJD1667W
    Recently the machine has not be draining (E20 error) and making a terrible noise when the pump is supposed to be working.
    Previously when this has happened (twice before over the past 12 months) I have manually drained the machine, removed the pump to clean it and replaced and everything has then worked fine.
    This time I have tired three times with no success. What do I do now?
    The pump is an Askoll 290793.
    I’m obviously happy to replace the pump but with it still making a noise I’m not convinced that it is broken….or is it?
    Please help!!
    #181296
    Dave_Conway
    Re: Drainage problem on Zanussi
    Foreign objects in the pump can eventually damage it, especially the Askoll type, as long as you’re sure there’s nothing in there, replacing it should do the trick (with the power off 😉 :zap:)
    This one will do nicely:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=165
    #181297
    nswan
    Will this pump be ok for a 1200 series Zanussi?
    #181298
    For your WJD1257W, the pump above will be fine. Alternately you can get the pukka thing from Zanussi – p/no 1249206/21-8 – for £37 plus VAT etc.
    nswan
    Thanks for that Penguin. These forums are very helpful and informative.
    Cheers. 😀
    #181300
    scarty10
    Sorry for the delay – only just signed back on again in the hope of a reply.
    Have ordered the pump you gave me the link for, so fingers crossed eh!
    Many thanks for your help Dave – top man!!
    #181301
    Dave_Conway
    Thanks for the orders scarty10 and nswan 😀
    #181302
    nswan
    No problem sir. Only found this site yesterday and I am hugely impressed. 😀
    #181303
    SBA99CEC
    😉 I have exactly same problem as Scarty 10 on my Zanussi WJD1667W so have ordered pump and fingers crossed.
    Many thanks
    #181304
    scarty10
    Pump replacement worked like a charm for me, so should do the trick for you also!
    Good luck!!
