Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Dreaded error codes
- This topic has 9 replies, 5 voices, and was last updated 3 years, 5 months ago by
Filbee.
October 9, 2022 at 10:26 am #101232
Filbee
ParticipantWe have a Bosch dishwasher that gives error code 24 on about 7 times out of 10 washes. We have tried the supplier but they have no clue and a call out charge that far exceeds the service they give. Dr Google and UTube have been exhausted, we have cleaned the filter well, there’s been no debris to speak of or broken glass fragments. We’ve changed soaps a few times but to no avail and made sure all inlet and outlet pipes are clear, they are.. Has anyone any ideas as to how I can solve this before I give in and buy a new one, which won’t be Bosch!
October 9, 2022 at 2:31 pm #483939iadom
ModeratorOctober 9, 2022 at 4:03 pm #483940Filbee
ParticipantInformation requested to help answer question previously:
E-Nr SM53M05ETU/04
FD8907 01559
Type SD6P1B
019070247914015596Many thanks
October 9, 2022 at 4:33 pm #483941iadom
ModeratorThanks, I’m out of the loop a bit these days, retired nearly five years ago. Hopefully one of the trade members with more up to date info will be able to help.:)
October 9, 2022 at 10:00 pm #483942kaibart
ModeratorDouble check the enr- number as its not recognised as a model number
October 10, 2022 at 5:28 am #483943Filbee
ParticipantMy apologies, sandwiched in between the M & the 5 in about a nanometre’s width is either a 1 or an I.
So it could read: E-Nr SM153M05ETU/04 or E-Nr SMI53M05ETU/04.October 10, 2022 at 7:31 am #483944electrofix
Moderatorfound another Bosch machine where error 24 was a drain fault
October 11, 2022 at 5:09 am #483945Filbee
ParticipantI have checked the drainage and there seems to be no problem with a blockage, at least in the pies I can easily examine.
October 11, 2022 at 6:12 am #483946matrixresonator
ParticipantI had a Neff recently (same as Bosch) recently with an intermittent drain problem.
Behind the left side panel is a water chamber (see attached pic). The hose to the outlet pipe and to the drain pump are connected to this, I removed the 2 hoses and sucked through everything with a wet vacuum and it cleared up, so I presume a bit of debris was I there occasionally causing an issue.Worth a try.
October 11, 2022 at 1:01 pm #483947Filbee
ParticipantI’ll certainly give it a go, thanks.
