Re: Dripping tumble dryer
Check and clean all the rubber seals around the porthole and condenser unit, before and after use, to get rid of fluff and debris.
I have the full size TC470 from 1998, and I religiously wipe the seals and their corresponding mating surfaces, before and after use.
I also leave the door ajar when not in use, to preserve the tension in the rubber seals.
With a condenser machine, it is vital to regularly BLAST water through the removable condensing unit, to remove the lint and fluff that does build up. Use a fast flowing cold tap, such as the garden tap, or the shower head. Make sure that the condensing unit’s integral seal (on the rear end) is also clean of old fluff.
DON’T insert sharp implements between the condenser vanes, to remove fluff; the condenser unit might get damaged.
