Drum bearin top loader philips/whirlpool AWG013
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Drum bearin top loader philips/whirlpool AWG013
  • #72722
    Morad
    In order to replace a drum bearing on the non driven side of a top loader philips/whirlpool AWG013 do you have to take the inner drum out or can you fix it from the outside of the big drum.
    I have managed to take out the alan bolt from the centre but cant get the ball bearing assembly out from outside of the big drum
    Also the part number for the big drum seal in case i need to open the big drum & have to replace it please.Cant find it on website.
    Is it all a very big job?
    Thankyou very much
    #385399
    EFS
    Re: Drum bearin top loader philips/whirlpool AWG013
    Drum out then push out the big wire clip and bearing assembly drops inside the tub.
    Check that the bearing assembly has not been rotating in it’s housing as the heat generated by the friction will have melted the plastic of the tub outer and it will be fubared.
    Steve.
    #385400
    Morad
    Thankyou very much Steve.
    Morad
