Drum bearings
  • #34410
    nikris92
    I have a Hotpoint Aquarius wf210/1100 spin washing machine with a very noisy drum when spinning. I have looked at some sites on the web and it sounds like the drum bearings, Are they expensive to buy. And would i be able to change them my self??????
    Kris
    #242521
    Re: Drum bearings
    If the machine is under five years old I would strongly advise you to contact the Indesit Company. Two different types of bearings used. Very difficult to remove, often requires new drum shaft and even rear drum half.
    You will get all the parts free, you will only have to pay the labour, not worth getting stuck halfway through and finding you cannot repair it.
    nikris92
    iadom wrote:If the machine is under five years old I would strongly advise you to contact the Indesit Company. Two different types of bearings used. Very difficult to remove, often requires new drum shaft and even rear drum half.
    Hi Jim
    Thanks for your reply.
    Any ideas how much for an engineer to carry out the work???
    Kris
    #242523
    Re: Drum bearings
    Is the machine under or over five years old. If it is under then it is very doubtful a local engineer would be able to do this repair for less than Hotpoints labour only charge.
    kiddo66
    Re: Drum bearings
    If you live outside London it will cost just short of ninety quid.
    #242525
    helo_75
    does it cost more if you live in london then?
    #242526
    kiddo66
    Re: Drum bearings
    A tenner extra.(dont know why,well to do with London innit)
