drum lifters
  • #88191
    wilf
    just a general question. how do different people fit drum lifters in particular the later hotpoint ones? the wma were simple with a satisfying click as they locked into place. the later ones with the tag at right angles to the paddle are more troublesome. I have a small hook that I use with difficulty to insert through the top holes to lift the tab to stop the paddle sliding back and off. poor design if you ask me. someone I spoke to said just push them on and forget them but the last thing I want is a disconnected paddle and a tag shredding laundry.
    wilf
    #437305
    Re: drum lifters
    If you just push them on they will come right off in no time at all.
    Like you I use a small hooked wire but first I carefully push the tab flat and then bend/twist the tab so it sits at a slight angle sloping upwards, towards the back before I push the lifter home.
    I then use the wire to try and pull the tab up a little more.
    The official fix for a broken tab is to drill a tiny hole in front of the lifter and fit a very short, stainless steel screw through the drum.
    #437306
    Re: drum lifters
    iadom wrote: The official fix for a broken tab is to drill a tiny hole in front of the lifter and fit a very short, stainless steel screw through the drum.
    Drilling into wafer thin stainless will be challenging. I bet they don’t include a stainless screw either?
    #437307
    Re: drum lifters
    Oh yes they do, there is an official TB, with drill size and part number for the screw. 😛
    #437308
    wilf
    Re: drum lifters
    any chance of that info?
    wilf
    #437309
    Re: drum lifters
    Had a trawl through all my files and can’t find a copy, it was a few years ago now, not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure I actually saved one. 🙁
    It was only intend to be a last resort fix if the tab had broken off completely.
    #437310
    Re: drum lifters
    wilf wrote:any chance of that info?
    Probably a Size2x3/8 stainless steel screw but drilling into such a thin drum accurately and without incident challenging in the extreme.
    #437311
    wilf
    Re: drum lifters
    have seen someone recommend pre drilling a small hole into the side of the new paddle in order to be able to insert a small screwdriver to lift the tab.
    wilf
    #437312
    HotDog
    Re: drum lifters
    This might sound ify but i have done this many times super glue them in if the tab is broke never had a come back
