BOSCH WAA28160GB
Washer has be working working well for a few years with no issues. It stopped turning one day and i quickly identified the brushes had worn down and one was no longer contacting. Replaced brushes and now the motor is working perfectly but running running super hot 80 C plus all the time.
Have checked
Everthing is turning smothly and free
Brushes are the correct way round
Brushes are moving free and making good contact
Brush holders are in perfect condition
Plugs are fully engaged and crimps are good
Comutator has no shorts on any windings
Cables are all good
Drum is not overfilling and causing drag
Is there a transister or cap that can go short circut and cause this. Possibly caused by the enevatable arcing caused when the orginal brushes worn out.
Advise would be greatfully recieved. Im sure this is a common issue.
