Drum noise on spin –
Viewing 15 posts - 1 through 15 (of 23 total)
  • #47503
    midi
    My Hoover 1300 special edition started to make noises on the fast spin cycle – there was a kitchen rug in the machine at the time (I didn’t do it I hasten to add)
    At first it looked as if the drum was running off centre from the door seal. Further investigation found that the drum has left/right play. The fault seems to go if the drum is centred – but can return. My worst fears is that it’s the ❓ ………..No someone confirm it before I say it.
    At the moment it going smoothly through the wash cycle – no noises
    Thanks and I hope I’m wrong
    George
    #293667
    midi
    Re: Drum noise on spin –
    Update
    Now making noise during the wash cycle
    George
    #293668
    It is probably either collapsed drum bearings or a broken drum support spider. In other words, a major repair and you need to decide if it’s worth repairing or buy new.
    #293669
    midi
    Thanks for the reply
    Sounds like Rolf Harris with his wobble board at the moment
    My worst fear confirmed the bearing
    Your right I need to decide if to repair – 7 years old, but been pleased with it so far – quiet and relaible
    Is there a forum that gives advice on a replacment machine –
    My spec is
    good reliable brand
    not many programmes with half load capability
    simpler the better – less room for failures
    Any other attribute I should consider?
    Thanks – but feeling rather fed up at the moment
    George
    #293670
    midi
    On reflectionof my post above
    Any idea how much to get fixed by a profesional (ballpark guess)
    Any idea how much if I did it myself? and any links to the procedure. After all I can’t make things any worse, can I?
    George
    #293671
    Model number please, George.
    midi
    CA 230 my friend
    #293673
    Drum and shaft as an assembly – about £95 – p/no 97910285. spares@ukwhitegoods.co.uk will get you one promptly if you wished to go ahead.
    This job will take a repairer the best part of two hours. The entire tub assembly needs to be removed from the machine and split, so the cabinet needs to be stripped as well.
    Labour rates vary widely across the UK – up ‘ere in’t north, you’d be looking at £75 from me – £45 for the first hour and £30 for the second. Dahn Saaf you can probably add on half as much again.
    If you do do this yourself, take pics and make diagrams……
    midi
    Thanks for the advice my friend
    Ned to think about it – getting near the price of a new washer – well it may be haven’t priced one up in a few years
    Take care
    George
    The People’s Rebulic of Newcastle
    #293675
    helo_75
    http://www.comet.co.uk/shopcomet/produc … WAE24164GB
    dont settle for anything less
    dont be sucked in by the specs of the cheaper machines, especially haier, they might be silver, but they look shiny on the tip
    #293676
    cockney steve
    It may be that only the bearings have gone, in which case the bearing/seal kit is probably less than £20……if the drum-support is broken, you’ll probably have to strip it out in order to confirm that. A new drum/support assy. + seal/bearings would be a bit expensive, but you’d wind up with something FAR better than the budget ~£200 throwaway non-repairable machines. For something of reasonable quality it has to be the Bosch as posted by Helo75, or maybe consider the ISE…It’s distributed ,installed and serviced by independent engineers and specified by them to give the best service-life for the price and be easy and cheap to repair. see links on the side of the page 🙂
    #293677
    cockney steve wrote:if the drum-support is broken, you’ll probably have to strip it out in order to confirm that.
    There’s really no need cockney, the evidence has already been established that it’s definitely broken without looking.:wink:
    midi wrote:At first it looked as if the drum was running off centre from the door seal
    Phidom wrote:It is probably either collapsed drum bearings or a broken drum support spider.
    Penguin45 wrote:Drum and shaft as an assembly – about £95 – p/no 97910285
    #293678
    midi
    Helo75, Cockney Steve Martin, Penguin45 and Phidom
    First thanks for taking the time to reply to my query. 😀
    From what I read on the tips page regarding stripping down a Hoover, it’s a real pain of a job and if its going to cost me a lot of time (and a few choice words 😡 ) and a hefty slug of cash if it’s the spider (would also do the bearing at the same time) maybe the end of the road has come for the machine. Although this pains me – I hate the waste of equipment, but maybe it’s the most cost effective option is to get rid ➡ .
    The old girl wants me to get someone in to give a quote for the work – since the spider seems to be the most expense is it reasonable him/her be able to pronounce on it before stripping it down – don’t want any nasty surprises half way through the job 😯 .
    With respect to a replacement, I looked through the other forum, and as usual with electrical goods lots of different pinions and experiences. Bosch seems to figure quite a lot and ISE is always mentioned. So its one of those. If others have a view point 💡 please feel free to advise or argue.
    The first machine we had was an Ariston – and in the words of the advert it went on and on. I think in all it was 14 years -couple of visits from the man to stop it over filling and me putting a new belt on. Changed it when we moved to the new house. If I could find a machine as reliable and simple as that I’d be chuffed 😀 😀 😀 .
    Thanks again chaps – much appreciated
    George
    #293679
    cockney steve
    A quick ‘n dirty check 😉
    open the door, try wobbling the inner-drum around…..if it wobbles off-centre to the porthole EVENLY and revolves “evenly”, – It’s likely to be bearings……especially if it rumbles when being revolved.
    the Spider is normally bolted to the drum edges at the same position as the lifter-bars (agitators) when you pull the drum off-centre and it STAYS that way, revolves eccentrically and scrapes when the off-centre bit passes the lowest point (scrapes the heater!)…..almost certainly the spider…..crunching noises when you pull it around, off centre,would suggest the broken ends rubbing together. you can even work out which leg(s) are broken.
    Don’t discount the possibility that a small independent shop might break one and sell you a used part cheap. those sort of placesare going fast and should be supported!
    #293680
    Also worth wobbling the drum and observing the rear pulley. If the drum wobbles but the pulley doesn’t you know the spider has failed.
