Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › DRUM NOT MOVING WHEN FULL
- This topic has 7 replies, 7 voices, and was last updated 18 years, 3 months ago by
jasonbl1.
December 17, 2007 at 12:36 am #33057
jasonbl1
ParticipantHI I HAVE A PROBLEM WITH MY TUMBLE DRYER. THE DRUM WILL ONLY SPIN WHEN EMPTY. THE DRUM WILL SPIN IF YOU START IT OFF WHEN IT IS LOADED. USED IT LIKE THAT FOR ABOUT TWO WEEKS AND NOW IT IS NOT HEATING UP. PLEASE HELP!!!!!
December 17, 2007 at 1:12 am #237277Penguin45
ParticipantRe: DRUM NOT MOVING WHEN FULL
Give us a clue, Jason – Make and Model………..
December 17, 2007 at 2:29 pm #237278helo_75
Participantbet ya life its a ctdoop/is70c!!!
it’ll want a capacitor and the cut out resetting
December 17, 2007 at 4:02 pm #237279DDSDDS
Might be a white knight.
December 17, 2007 at 4:32 pm #237280Martin
Participanthelo_75 wrote:bet ya life its a ctdoop/is70c!!!
DDSDDS wrote:Might be a white knight.
What is this? :con:
It’ll be Tarot Cards and Tealeaf reading next from you guys will it?
Can you predict what 6 numbers I need for next Weds Lottery please while you’re at it :martin:
December 17, 2007 at 4:40 pm #237281DDSDDS
I f i could see the numbers for next weeks lotto i would not tell anyone.
i would away to a big house in the country and get some other poor buggar to fix my washer when it broke.
i might even buy an indesit just for the fun of it or maybe a new “lack of servis “
:snigger:November 30, 2024 at 4:40 pm #237282Paul0729
Participantwhite knight c45cw drum not turning when loaded. turns when empty
November 30, 2024 at 10:10 pm #237283andyjawa
ParticipantHi Paul. 9 times out of 10 it`ll be the motor capacitor that has failed ( common failure point) – the cylindrical shaped component with a couple of wires going to it attached to the motor. From memory, though it will be written on the component, it is a 10uf capacitor. W/Knight original spares probably all gone as company closed down and the name taken over by Turkish company – usual UK self destruction. All you will most likely need is a new capacitor so just check your capacitor to check the uF and search for a good quality one via Ebay should cost you 12 quidish – the cheap Chinese ones are not very good so avoid those! You should only need to remove the rear bottom part of the back cover and screws and the vent pipe`s 2 screws. Obviously POWER OFF and leave for 30 mins to allow the capacitor to discharge should you have tried it just before going to disassemble the machine just in case!.
Could also be the belt frayed or nuked drum support but both doubtful. -
