The repair is probably very simple for an engineer….most likely the motor brushes have failed. If you feel unable to check this yourself then it’s time to call an engineer for what should be a quick and easy (cheap) repair.
Have a look in Repairs@ if you need an engineer, but if you’re going to have a go then you must of course unplug the appliance before doing anything else.
