Drum paddles Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › Drum paddles This topic has 9 replies, 4 voices, and was last updated 16 years, 2 months ago by kladave. Viewing 10 posts - 1 through 10 (of 10 total) Author Posts February 6, 2010 at 11:42 am #52281 kladaveParticipant ISE2 1242w Any trick to getting these on Dave February 11, 2010 at 8:15 pm #311190 iadomModerator Re: Drum paddles Well, was there…? 🙂 Never done one. February 11, 2010 at 8:59 pm #311191 Penguin45Participant Re: Drum paddles Place… slide…. walk…. :p45: February 11, 2010 at 11:02 pm #311192 iadomModerator Re: Drum paddles Penguin45 wrote:Place… slide…. walk…. :p45: Followed by a fishtail and a shimmy no doubt. 😆 Jim. February 12, 2010 at 12:08 am #311193 Penguin45Participant Re: Drum paddles Only if it’s icy – can do the tummy sliding thing then.. 😀 Chris. February 12, 2010 at 8:52 am #311194 kladaveParticipant Re: Drum paddles iadom wrote:Well, was there…? 🙂 Never done one. No,i’m putting them in the freezer to see if that works,Chris i do understand that they slide in but you can’t get enough force from the rear of the drum to force them forward. Dave February 12, 2010 at 8:48 pm #311195 deltraParticipant Re: Drum paddles i gently opened the plastic lugs, then pushed them on,making sure that the securing tab was in correct place (about 2mm up) April 13, 2010 at 8:58 pm #311196 iadomModerator Re: Drum paddles Just to come back to this one, may have to remove a drum lifter on a Vestel ISE5-2 tomorrow, how easy are they to take out and will they refit? April 14, 2010 at 7:51 am #311197 kladaveParticipant Re: Drum paddles Jim I ended up opening the tabs a little to get them to slide on. As to your first question,the paddles were already off/damaged. Dave April 14, 2010 at 10:13 am #311198 iadomModerator Re: Drum paddles Not actually seen one off and didn’t bother risking it this morning. I wanted to see if there was a suitable hole underneath to check on any foreign bodies that might be in the drum. Author Posts Viewing 10 posts - 1 through 10 (of 10 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
