As you have probably found out that the bearing change is far from simple. To access this the rear panel needs removing and the machine laying carefully on its front, beyond that you’re on your own with that problem I’m afraid 🙁
The best advice I can give is let us independent experts do the job for you, check out this link for one : Repairs@
