Drum spring replacement WFT2800GB/13
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Drum spring replacement WFT2800GB/13
  • #52347
    wkrzp
    Can anyone give some guidance on replacement of the drum support springs on a Bosch WFT2800GB13 please?
    Machine is noisy/vibrating on spin.
    Have replaced both shock absorbers, and have new springs from Bosch, but replacement does not seem to be as straightforward as I expected.
    (Machine is over 10 years old).
    Regards
    Stephen
    #311424
    Re: Drum spring replacement WFT2800GB/13
    The only time you ever need to replace a suspension spring on one of these is if it physically breaks.
    Major vibration problems are usually down to drain issues. Filter is pretty obvious, sink coupling (if appropriate) is worth checking, failing that, check the air break bottle at the back – they clag up overtime and slow the drain flow.
    Power off first bfore doing anything internal.
