I’ve got a 6 year old Siemens WM14S392GB/10. Recently it stopped spinning and an error code (F43) came-up. I replaced the carbon brushes, plugged it in and it worked on a test spin. Great – first time I’ve done changed them.
However during the 1st full test wash the drum stopped turning. I left it running to watch it. As it went onto spin there was a white spark and the circuit breaker tripped.
I checked the fuse – it was fine. I checked the belt – fine. Then I gingerly plugged it back in; the machine is as it was, ie it has power and will run a wash cycle, but the drum doesn’t turn. I’ve taken the motor out again and checked the brushes, all seem OK. Based on an eSpares video I used a voltmeter to check the motor. I didn’t get any kind of a reading from the terminals associated with the carbon brushes – although it may have been ‘user error’ on my part.
Any advice?
Michael
