Drum strut/dampeners broken – Fix or Ditch?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Drum strut/dampeners broken – Fix or Ditch?
  • #36638
    AKR
    New to the forum (obviously) and came across your forum when trying to find a solution to my washing machines problems.
    I have an Ariston AB95 washing machine that recently started going crazy and banging noisly when gearing up to do the spin cycle. I took the back off it today and discovered that the strut things have completely snapped off from the base of the machine on both sides. 😕
    Up until now we’d never had a problem in all the years we have had the thing. Would the struts breaking have been caused by another problem, or could I put it down to the fact it was dropped off the back of the moving truck when we moved into our new home about a year ago now? :rolls:
    Worth an attempt at a DIY fix or just ditch it and get a new machine?
    Thanks in advance, great site you have here, can tell you are a knowledgeable bunch!
    #251787
    helo_75
    theres a kit for that..ill see if i can get the nmnber for you
    #251788
    helo_75
    C00110233 is the number for a cabinet plate, and shoud go some way to solving your problem
    #251789
    helo_75
    or 2 of if theyve both broken
