Dryer fan (Whirlpool AZA9791)
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Dryer fan (Whirlpool AZA9791)
  • #93187
    Garetht
    Got a grinding noise from the tumble and now that I have taken it apart I have found the dryer fan just spins freely around the shaft from the motor.
    Am I correct in thinking that the fan should be securely fixed to the shaft from the motor ?
    A picture is uploaded so you can see the fan part.
    Gareth
    #453457
    Re: Dryer fan (Whirlpool AZA9791)
    yes should be fixed to the shaft
    part number 481010425277
    you could ask the site shop if they can supply
    Garetht
    Great, appreciate the help Dave.
    #453459
    Alan
    ​​I have exactly the same problem so I removed the motor and fan etc. but I can’t get the fan off the spindle!
    I have tried gentle brute force but it won’t budge.
    Is there a trick to getting the fan of the spindle?
    #453460
    if the fan is spinning on the shaft on should come off easily. try turning it as your pulling but you will have to stop the motor turning at the same time
    Alan
    Hi Dave
    I have the full motor assembly out of the machine and removed the nut that is supposed to hold the fan in place but the damn fan won’t come off the spindle even though it’s completely loose and wobbles.
    It’s as though there is a spring washer or something holding onto it no matter how much I pull or hit it.
    I even tried a screwdriver and hammer to the back of it.
    #453462
    well all I can suggest is to carefully cut it off. you can use something like a soldering iron to melt parts of it to try and split it or junior hacksaw even a Dremel if you have one
    fan is expendable so don’t worry what you do to it as long as there is no damage to the motor
    Alan
    At this moment I feel like using a lump hammer on the bloody thing!
    Cutting looks like my only option as there is nothing holding it on but it won’t come off …. Weird!
    Cheers
