Re: Dryer Vent location inaccessible
It’s puzzling to me how the vent outer grill was fitted being as there’s a fence so close? Or could it simply be a large hole in the wall and your fence abuts that hole just 5cms away?
Either way there is little or no danger your fence could be damaged from such a vent. A degree of steam will exhaust but again should not affect or compromise your fence or boundary.
Access and cleaning is a worry though, especially leaves in the Autumn and snow in the Winter. Though again that will only cause your neighbour and his dryer a problem and not affect you or your fence.
If I were your neighbour I would have sought a more sensible solution by buying a condenser dryer thereby eliminating the need for a vent. Or to relocate the vent ( if at all possible ) to a more serviceable location.
