Dryer wont start on my mains at home but works in the shop I bought it from .
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Dryer wont start on my mains at home but works in the shop I bought it from .
  • #94781
    .Colossus.
    I Bought a Tumble Dryer from a shop. They deal with Beko cast offs and repair/resell them to the consumer. In most instances I have bought these products with no problems and they work fine. This Tumble dryer was bought home and although it powered up (interface) , the unit refused to spin or heat up. I took it back only to witness at the repair shop , it worked fine. Can you advise me what could possibly cause this . I have tried it on various sockets (that work) in the Kitchen and another room in the house . It refuses to work. EVERYTHING else works on these sockets , dishwasher, kettle, fridge, buzz saw , drills ,vacuum cleaner, microwave, cooker, … everything. I might have to take it back but its isn’t faulty but it doesn’t work on my home circuit ?? Weird!!
    #458318
    don
    What’s the model number of the Beko ?
    #458319
    What has the shop said ?
    As a retailer I would have got involved in finding a problem as its very strange
    I assume you are on mains power and not using generators
    As a long shot have you tried it either next door or at any of your friends houses
    .Colossus.
    Hi don, hi Dave. Model is DCJ83133w. Shop is as stumped as I am. He said take it back and try again different sockets maybe. On mains power . Not taken it next door due to taking it back and forth to shop without damaging it every time I is moved
    #458321
    don
    Is there any symbol showing in the display when you attempt to power it up?
    #458322
    just out of interest I checked the error codes
    the machine will stop if the voltage on the mains goes below 165V or above 265V
    This would be highly unlikely and you would have had other things blow
    I bet a quick ‘ Martindale socket checker’ will show the house wiring is at fault. Live/neutral reversed or worst still earth return not connected maybe?
    #458324
    .Colossus.
    When I switch it on, it lights up, selection device lights, then press start button , and the drying and star/ pause leds light up and thats it. When in the shop, a click is heard and the spin cycle starts up. The Voltage is 247v according to my multimeter , tested ground earth and same reading .
    #458325
    could be an intermittent fault that just happened to not be there the day you took it back
    that why you need to try another supply
    you could ask next door to give you an extension lead for 5 mins just to give it a quick try
