Just come back from a week away and as is always the way, something has broken – namely my Beko DSC85W. When I try to dry any clothes, I get no heat. Have popped the back off and checked the trip switch (which hadn’t tripped), checked the NTC thermostat next to it which had a resistance of 4.5k (is this within tolerance?), but no dice. I decided to find out if the heating element was being powered up at all, and so plugged the drier in through one of those “energy consumption readout” plug things – this shows me that when I first start the program, it draws about 2.6KW of power, which is about right for the element being on. I can then hear the relay click on and off a couple of times, then when it switches to the reverse spin cycle, the heater goes off never to come on again (with the drier consuming just 150W or so).
I thought it might just be a dodgy element, but further reading says it could be the main PCB as well – anyone had this problem, and been able to fix it? Any help would be appreciated…
Cheers
JD
