DST 10146P
  • #76994
    mattmob751
    I’ve got a Hoover DST10146P 10kg Washing Machine, When it,s switched on all it does is display the “Kg Mode” and the LED’s on the selector constantly go round and round, the machine is 3yrs old.
    Any help on this would be appreciated.
    #400348
    Re: DST 10146P
    There’s nothing that would give any indication of what this is in the technical info.
    Is there any error code being displayed?
    mattmob751
    Re: DST 10146P
    No, there’s no error code or any indication. On inspection everything is clear, drum empty, pump free and so on??
    #400350
    Re: DST 10146P
    It’s possibly a board failure if you can’t see anything else untoward such as a failed component from testing but do check that all the plugs are secure if you go into the machine as that can fox the software.
    mixerman646
    Re: DST 10146P
    Hi, did anyone find the fault on this as mine has now done exactly the same?
