Dual grill regulator change -extra neutral -Help
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Dual grill regulator change -extra neutral -Help
  • #95614
    belling
    I am changing the dual grill regulator on a belling 626 @20 years old.
    The old one is 33ER3MHT and is no longer available but have been sent a suitable alternative EGO 505507310.
    My problem is that there are 2 neutral connectors on the old unit but I can only find instructions for one neutral on the new one.
    Connectors labelled P1x2,2,P2,4,4a,S1,S2.
    Any ideas?
    #460881
    you either need an adapter to add 2 wires or add a piggy back terminal to the end of one of the wires
    or since the neutral carries no real load at this point follow the cable along the line of regulators and see if the next one has a spare terminal and if it reaches pop it on there
    belling
    That is a simple solution.
    Also can you confirm I need to add a link wire from S1 to P1 to make the heat light work?
    #460883
    very likely older units are linked internally but later one are not
    belling
    Just finished fitting regulator and can confirm all working 😎
