DUALIT 3 SLICE TOASTER
Home Forums Public Support Forums Help And Support Cooker And Oven Forum DUALIT 3 SLICE TOASTER
Viewing 15 posts - 1 through 15 (of 15 total)
  • #38594
    beetlebug
    HELLO
    DOES ANYONE OUT THERE HAVE A WIRING DIAGRAM FOR A DUALIT 3 SLICE TOASTER, I UNWIRED IT TO REPLACE 2 ELEMENTS AND NOW CAN’T REMEMBER WHERE THEY GO.
    MANY THANKS
    #259374
    smartin
    Re: DUALIT 3 SLICE TOASTER
    see rule 8 under professional advise at top of forum.
    #259375
    beetlebug
    an retired white goods repair man is doing the job for me but said it would be easier with a wiring diagram. as this site has been very helpful in the past i thought i would try here first.
    #259376
    beetlebug
    if there is no one on this site that can help perhaps you could point me in the right direction.
    #259377
    helo_75
    http://www.comet.co.uk/shopcomet/produc … 0WTTM40401
    is probably the best place to start looking to be honest
    #259378
    beetlebug
    how is a kenwood four slice toaster from kenwood going to help.!!!
    #259379
    helo_75
    it will toast your bread, which is evidentally more than your current one does!
    #259380
    beetlebug
    yes it will but i would rather fix my dualit. i have a spare toaster so toasting is not a problem. the problem is my memory & three children who i belive were just put there to distract me. the next time i take something apart i will take photo’s as i go. it worked with the washing machine, thats whats so annoying.
    #259381
    I have absolutely no idea where you’ll get a wiring diagram, but apply a little logic here………..
    There’ll be a common neutral across the elements, then a selector to supply 1/2/3 slices? Each ‘slot’ will have it’s own supply and the selector will switch them on incrementally from 1-3. Five minutes with a multimeter should figure that out….
    Obviously, with the plug out!
    Dualit machines are worth fixing Helo, a whole lot better than junk like that Kenwood pile of rubbish which, let’s face it, is a throw-away pile of crap. I’d also wager they do a slightly better job, just a bit.
    I don’t have access to Dualit technical information but I’m sure P45 is right, it can’t be that hard to work out. I’d also think that Dualit would help.
    don
    We had one of these in last week for a new timer if it has not yet been collected I`ll post a piccy of the underside.
    If it has gone then I`m sure as K says Dualit should be able to help.
    Dualit Tel 01293 652 500
    Fax 01293 652 555
    email info@dualit.com
    Don
    #259384
    beetlebug
    thanks don
    fingers crossed that it hasn’t left the shop yet.
    if not i need to find a friend with a multimeter.
    thanks again
    #259385
    don
    Sorry beetlebug but it was collected on Friday. Looks like a job for a multimeter or on the phone to Dualit.
    Don
    #259386
    beetlebug
    hello all
    spoke to a very helpful lady called samantha at dualit who has ent me a wiring diagram. so once the kids are in bed this evening i will put it all back together.
    thanks
    #259387
    beetlebug
    hello all
    it took a little longer than expected. don’t you just hate the school holidays. success !!! i have toast again. if anyone needs a wiring diagram i have one.
    thanks for your help
