Duct Feed Pipe Splitting on Drying Cylce
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Duct Feed Pipe Splitting on Drying Cylce
  • #44474
    cr73
    I have a Hoover 1500 Special Edition Washer Dryer. It has worked fine for 3 years or so but, during a drying cycle, it suddenly made a loudish cracking noise and started to leak water from under the machine. It was still fine during the washing cycles but always leaked when drying. I took it apart and discovered the duct feed pipe was split. I replaced this and then, after about 30 minutes of its first dry cycle, I heard the same cracking noise and it started to leak again. I assume exactly the same thing has happened and the pipe is split again. I don’t really know what I’m doing so would appreciate any help anyone can offer. Does anyone know why this is happening? Thanks,
    Chris
    p.s. it’s model number HSW 150 M-80 if that’s any help.
    #281088
    suedehead1
    Re: Duct Feed Pipe Splitting on Drying Cylce
    the cold water valve should have a flow restrictor in the end of it which reduces the amount of water going through the valve as far as i can remember, however if your water pressure is too high that can also burst the hose. when you fit the new hose try the dryer and watch the hose if it starts to swell up, if it does there is a problem and te flow restrictor may have came out.
    plug out if working on the machine of course.
