Dw Bosch SMS40C02gb/03 – E18 error Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Dw Bosch SMS40C02gb/03 – E18 error This topic has 2 replies, 2 voices, and was last updated 11 years, 3 months ago by twicknix. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts January 5, 2015 at 1:22 pm #83612 twicknixParticipant According to fault code it says low water level. I replaced the inlet hose as it was clogged up and cleaned out the red valve inlet. It works fine on quick wash but not on Normal wash 65deg. It shows up E18? I reset it and tried again and it works? The replacement inlet valve is out of stock, I’m not really sure that the valve is the problem. Any pointers? Matt Sent from my iPad using Tapatalk January 5, 2015 at 4:29 pm #423264 MartinParticipant Re: Dw Bosch SMS40C02gb/03 – E18 error Flow meter reed switch maybe? January 5, 2015 at 7:21 pm #423265 twicknixParticipant Re: Dw Bosch SMS40C02gb/03 – E18 error I thought the same too. Will keep you posted on the outcome. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
