Dwf 30p
  • #99855
    clockworkone
    Hotpoint/Bosch Dwf30p/17. No display illuminated. Nothing happens. On/off switch possibly faulty. 6 tag switch
    . Looking from left to right tags 1 and 2 open and close with on/off button,3 and 4 the same. But 5 and 6 do not. Door latch in closed position when tested.
    #478174
    Think I may still have the manual for that. PM me an email address and I will send it to you if I can find it.
    Jim
    #478175
    have you got the Fd number drom the label ?
    I have a feeling this has momentary switches that only make for a split second as the button is first pushed. Have found the full pdf manual.:cool:
    #478177
    iadom wrote:I have a feeling this has momentary switches that only make for a split second as the button is first pushed. Have found the full pdf manual.:cool:
    was also thinking some of these were on a recall due to relay problems blowing up the board
    https://www.hotpointservice.co.uk/safety-notice-dishwasher
    The manual is dated 2001 so getting on a bit.
    #478179
    clockworkone
    Many thanks for replies. Email is..appliancerepairs1@eircom.net
    #478180
    clockworkone wrote:Many thanks for replies. Email is..appliancerepairs1@eircom.net
    Can you check that email address, bouncing back as invalid.
    Sorted, I just clicked on your link but you didn’t leave a space between is.. and your email address so removed that and you should now have the manual.
    Jim
    #478181
    clockworkone
    Many thanks for that Jim. Appreciate all your effort.
