Hi wondered if anyone could help
Water was not beeing drained from the machine so began to investigate. Once inside could see the motor for the pump running but no water going out. Taken the pump out and found the piece of plastic that connects the impeller to the motor armeture has broken, motor spins but impellor doesnt.
Only need the impeller assembly as the motor is fine. Anyone know where i could find it?
No.s – 8545 856 15600
– 99 0403 001268
Any help will be much appreciated, cheers James
