DWF 64 SS
  • #37649
    wildman
    I have a DWF 64 SS
    It had a water leak which destroyed the motor with salt and detergent…it subsequently kept tripping out the mains….
    The motor was replaced and now the machine fills up and keeps on washing over and over….and never finishes…It was running for over three hours recently
    When I select the button to empty the washer it empties and seems to keep on pumping out
    What would be the most likely problem be
    #255938
    Re: DWF 64 SS
    What’s it actually doing? Does it actually run the programme and then repeat? Is it getting started and then hanging up? Does is heat?
    The programmer is an electro-mechanical one, so the failure of any given function can cause the programme to over-run.
    We left your previous thread with you replacing the pump housing, has the machine been functional since then?
    wildman
    Re: DWF 64 SS
    It did indeed work fine for several months…then the flood occured which destroyed the motor….Now it seems to run….ie water fills up and it just cycles through the wash…but not actually doing anything…the water does not heat up….
    So far….I’ve replaced the motor assembly and the heater….
    Brgds
    Steve
    #255940
    wildman
    Re: DWF 64 SS
    replacing the pump impellor did solve the original problem….the problem now is it keeps filling up and washing even on a short cycle it never finishes….
    The water appears to be luke warm…..
    Steve
