DWF 64SSE TYPE 10045 – Help !
Home Forums Public Support Forums Help And Support Dishwasher Help Forum DWF 64SSE TYPE 10045 – Help !
  • #10651
    Hi all
    My SMEG DWF 64SSE has broken, bascially when i turn it on and select a programme nothing happens, the power is getting in as the buttons light up when pressed etc. The start/stop button beeps when you press it, but basically nothing !
    Shoud I try the reset procedure (door open 4 presses of the on off button) or the bendy tube cleaning procedure under the little black flap ?!?
    Can anyone help please…
    Many thanks
    Will
    #141289
    Re: DWF 64SSE TYPE 10045 – Help !
    Reset procdure will do no harm if you try it (start button 4 times BTW, not on/off). If the programme appears to select but doesn’t start I’d be more inclined to check the door latch/switch mechanism. The programme cannot start if the door is not shut properly.
    Power off of course :plug:
    Lawrence
    From the symptons you describe their is a strong possibility you will need a replacement dispenser assy ,But you would need an engineer to verify this ,try repairs at or directories for an engineer near you
    Regards
    Lawrence
