Dear Expert
Dishwasher went onto its wash cycle OK but did not progress After removing power all water (it was cold) was drained and heater measured 22.7 ohms and micro sw measured OK Machine was then switched on with main program but no water came into drum Mains pressure is OK There is only a low hum from pump Suspected input solenoid fault? It measures 3.5 kohms with an open cct voltage of 85vac across disconnected terminals
Is this normal? Advice would be greatly appreciated
Thanks for reading lexmacd
