DWF32 Dishwasher not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum DWF32 Dishwasher not draining
  • #73229
    ianmjames
    Hi, I have a DWF32 dishwasher which has been working fine until yesterday.
    After a wash I noticed the base was still full of water i.e. had not drained. After a lot of ‘googling’ I have taken the following steps:
    a) removed and checked filters
    b) checked hoses for blockages (the ones outside the machine)
    c) taken the top and side panels off
    d) checked the red float switch is not stuck (it wasn’t)
    e) bailed out the inside and retried – no change
    When I turn on the machine I can hear a sound like a pump for couple of minutes but no water is expelled.
    I would like to check that the pump is not blocked but cannot see how to get into the machine. It looks like I will have to lay the machine on its back but I am still not sure whether this will allow the base to be removed.
    Do I need to remove the base to access the pump?
    One other observation on the left hand side of the machine is a plastic tube ‘network’ and the top left appears to be full of ‘crud’. Is this important i.e. is it some kind of crude pressure sensor and should I attempt to clean it. In order to clean it I would need to disconnect three hoses located at the bottom but I am concerned that they may not seal properly afterwards.
    Any help/hints etc. would be greatly appreciated.
    Ian James
    #386838
    Allsorts
    Re: DWF32 Dishwasher not draining
    That crud will be stopping it draining…
    #386839
    ianmjames
    Thank you allsorts.
    Can you possibly explain how it is stopping the water draining?
    Ian
