I have cleaned fat out of the pressure sensor and tried a voltmeter on the flow meter, it read something like 0.08 volts when filling. I cleaned the contacts to the flow meter. I am still getting 7 flashes.
Any ideas?
I have taken the reed switch out and tested it with a magnet, and continuity tester. It is still working when not in the machine. I dont have a way of testing if the number of pulses is 10 per second or greater until I go back to work.
I’ve had them work with a magnet out of m/c and then work for a short time once replaced, think you use a stronger magnet to test with.90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain it will be your problem.
