Hi I just wanted to check whether anyone can confirm a possible board fault on this machine? It drains only – there is no water in the base and the anti-flood has not been activated.
Thanks.
only other thing to check may be the float switch in the base, have been known to burn out the plug. remember these things do drain for a good 2minutes or so on first switching on.
