Re: DWI612C Wash pump & sump gasket.
Water was pouring through the sump seal, so I tightened the screws which appeared to stop the leak.
I noticed signs of a leak beneath the wash pump but when tested it didn’t appear to be a problem so not sure if this is caused by water left in the tray from the gasket or the pump. I couldn’t get the machine out without a lot of work so decided to see if tightening the sump screws would do the trick.
Having just had another call it looks as if the machine could still be leaking so I will have to go back and investigate further.
Thanks for the part numbers, at least I can go back remove the machine and quote for whatever’s needed.
