hi this machine has no motor action when i looked up pcb i can only find the one behind the facia as there are no relays on it i assume there is another board any one know the part no please thanks john
Can you give us the full serial number, DYN9154DP isn’t recognised and DYN9154 brings up two models which both have the large main pcb at the top, right hand side (from front). They also show a module in the base but there are several versions of that so full serial number is essential.
