If you search the web there are references to the CR01 drain hose, If your freind can measure the connector spigot diameter on the rear of the machine you should be able to find a universal hose with a right angled end with the corect sized cuff in the whitegoods shop, alternately have a look on the auction site beginning with e and ending in bay, the hose is retained with a hose clip which is easily removed/replaced with a pair of narrow nose pliers, you may have to remove the machine back panel for better access to the hose clip.
Thanks for your reply. My friend has now contacted one of the engineers via this website and he’s going out to have a look at her washing machine tomorrow. She feels happier doing it that way.
