Dyson CR01 outer door problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Dyson CR01 outer door problem
  • #75332
    Johnnyboy
    Hi Guys I have a CR01 that say close outer door, as it is closed I am thinking the interlock, however how do you get at it?
    #394582
    Re: Dyson CR01 outer door problem
    take the front off
    have stripped a few of these as they tend to jam as they get older so need to be cleaned and lubricated
    its a mechanical lock operated by a solenoid so they don tend to blow up just jam
    Johnnyboy
    Cheers, however how does the complete plastic front come off? is it like Miele?
    #394584
    bit like
    remove control panel
    remove filter
    remove top screws
    remove 2 hidden screws in door hinge ( bit of a begger to get at )
    front lifts about half an inch and comes off ( can be a bit akward to get it to move )
    after front off there is a plug and fron comes off with door lock still attached
