Dyson DC01 Belt Breaking
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum Dyson DC01 Belt Breaking
  • #24487
    whutton
    The belt on my Dyson DC01 keeps breaking. At the point where the belt is breaks (it only breaks across about 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the width and then comes off) there is a lot of wear as if it has jammed and spun on the motor shaft. There are signs of wear on the plastic casing parts as if the belt has been rubbing. In fact some of the thin plastic webs next to the path of the belt are cut through.
    Any advice on what the problem might be ?
    William
    #202268
    helo_75
    Re: Dyson DC01 Belt Breaking
    yup
    the roller isnt running straight
    its because the hood isnt on properly
    youll probably find the opposite hood bush has come away
    on the other side of the cleaner from the belt, ull see a round yellow (or blue ) fitting , the hood will have come away
    bit awkward to put it back on, but it will go
    hope this helps
    #202269
    whutton
    Many thanks.
    I’ll give this a try.
    #202270
    Trilobite
    The agitator brush has a raised, bevelled section on which the belt runs. Through use, this has a tendency to wear. This can cause the belt to drift across and cause the problems you describe.
    In this scenario, a new agitator is required. Best contact Dyson, as there were variants as to the type of ends employed.
