Dyson DC04 drops vacuum
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum Dyson DC04 drops vacuum
  • #42932
    robinhood
    Anyone tell me why my wife’s Dyson DC04 drops vacuum intermittently? The way she gets it going again is to whack the cylinder with the palm of her hand with some force.
    The fault is most obvious when vacuuming a “mixed” floor where the machine has to go from, say, carpet to tiles.
    TIA
    #275415
    kladave
    Re: Dyson DC04 drops vacuum
    serial number would be a help.
    #275416
    ray.t
    Hi Is this a Zorbster dco4? Grey and lilac
    #275417
    kladave
    The switch is faulty inside the motor cover,thus only giving you half power/speed.
    #275418
    robinhood
    kladave wrote:The switch is faulty inside the motor cover,thus only giving you half power/speed.
    Apologies for the late reply.
    Thanks for the excellent advice. I should have looked at bit closer at the machine & I might have spotted the switch 🙂
    I’m hoping that by putting a couple of layers of masking tape on the dust collector to push the switch in further will fix the fault.
    If not, how do you change the switch?
    BTW this is a DC04 Zorbster S/No. 065UK 012155
    #275419
    kladave
    Brush bar out
    Brush housing out
    2x plastic circlips off either side of cleaner head
    Cleaner head off
    Hepa filter out
    6x torx 15 screws out
    You then have access.
    #275420
    robinhood
    That seems a lot of hassle but thanks anyway. I’m glad to say the masking tape fix seems to have worked.
    What’s the switch for? Is it just used to drop the vacuum when the dust collector is taken off?
    #275421
    kladave
    No
    It’s to do with the application of the zorb.
    #275422
    robinhood
    Thanks for the info.
    As the zorb feature has never been used I think I’ll leave the tape holding the switch down.
