Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › DYSON DC04 Dual CycloneHOOVER NOt PICKING UP,lacks suction
- This topic has 6 replies, 3 voices, and was last updated 20 years, 7 months ago by
lmcc67.
August 28, 2005 at 10:49 pm #11632
lmcc67
ParticipantHI CAN ANYONE HELP!
i have a DYSON DC04 Dual Cyclone HOOVER and when i use the hose part to hoover with it works great the suction is brillant, but when i use the bottom part
as a pull along hoover there is hardly any suction atall, wondered if anyone had any ideas as to what the problem is with it please
thank youAugust 28, 2005 at 10:57 pm #146076lmcc67
Participanti have only had this hoover for 2 months
August 28, 2005 at 11:42 pm #146077kwatt
KeymasterRe: DYSON DC04 Dual CycloneHOOVER NOt PICKING UP,lacks sucti
Hi LMCC67,
The correct terminology is vaccum cleaner, Hoover is a brand name that is simply synonomous with vaccuming a carpet. Not your fault at all, just a popular misconception as vaccuming has often been reffered to as “hoovering the carpet” which Hoover just love.
In any bagless cleaner the filters are absolutely critical to its operation, if they are dirty or blocked in any way whatsoever the performance will drop as a result. Sadly, in the case of many Dyson products this becomes all too apparent as the filters clog up and, in my experience, this leads to a drop in performance. I have also seen this cause motor failures and all sorts of other woes.
First thing to do is check the filters, make sure they’re clear and clean, if not then replace them, even the so-called “lifetime” filters as they do clog from what I see.
The other thing to be checking is the that the brush roll is clear and turning, not blocked with hair or other detrious material and that the belt is in place and correct. If the brush roll is blocked then the performance will be severely compromised.
Other than that it’s over to the vac guys to offer other tips.
August 28, 2005 at 11:56 pm #146078lmcc67
Participanthi kwatt
thank you for your terminology correction, never thought of that!!!! just thought “vacuming” was an American term as i work for an American and he uses that term!!!!!!
thank you also for your advice on my vaccum, i have just checked filters they seem pretty clean, checked the brush roll seems clear but doesnt spin when vaccum is on!!! maybe the belt?August 29, 2005 at 12:01 am #146079kwatt
KeymasterVery possibly the belt or bearings, but Dave should be able to help with either/or tomorrow.
August 29, 2005 at 12:14 pm #146080Goatboy
ParticipantRe: DYSON DC04 Dual CycloneHOOVER NOt PICKING UP,lacks sucti
It depends what colour the Dyson is.
The silver/Lime one (slime) is a clutchless model which is prone to belts snapping. It’s easily acessible with a 2p coin.
The silver/yellow one has a clutch. The brushroll will only rotate, once the head has been lowered. But on this model, I get that complaint alot when people have accidently disengaged the clutch.
September 16, 2005 at 8:50 pm #146081lmcc67
Participanthi, i just wanted to say again a big thank you to all the brilllant electricians/technicians/engineers on this site as by taking their advice and reading through lots of their replies to other people with similar problems that i had with my vacum cleaner, i was able to fix my vacum, just by changing the belt thanx Goatboy, once again many many thanks, you guys are brillant!!!!!!!
