Can anyone confirm colour code for wiring replacement motor on Dyson DC05. (Motorhead) ❓ Is it 2x Black to trailing connector and White wire to fixed terminal or vice versa?
Thanks. There are two identical single female spade connectors. One with 2 x black wires and 1 with single white. Would appreciate copy of wiring diagram if possible so I can trace the circuit.
jagmad wrote:Would appreciate copy of wiring diagram if possible so I can trace the circuit.
Sorry, I can’t do that.
What was the original problem?
If it was no motor action from that motorhead, it could be a module problem (from past expierience). These are notoriously awkward, and I’d recommend professional help from your local Dyson specialist.
Thanks, No its not the motorhead. I had that problem some time ago and dyson engineer replaced Wand handle. I checked the old one and it was only a loose wire so I now have a standby. The main motor has failed and I sent it to my local repairer (out of warranty) but replacement motor cost was 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of new Dyson. I now have a replacement motor but dealer disconnected wires in original and did not connect them back on returning it, hence my checking wiring before running up new motor.
