Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Dyson DC08
- This topic has 7 replies, 4 voices, and was last updated 15 years, 1 month ago by
dames.
February 28, 2011 at 11:39 am #61353
dames
ParticipantHi all ,
When I start up our DC08 it sounds like a flap/seal closing over?Is this just due to dirty filters or could it be something else?
Cheers
Dames 🙂
February 28, 2011 at 12:01 pm #345804don
ModeratorRe: Dyson DC08
Could be a blockage in the brush head, main hose or extension tubes.
Had a Smartie tube end jammed in a hose the other day which was causing a popping sound.
HTH 🙂
Don
February 28, 2011 at 5:35 pm #345805quickwash
ParticipantRe: Dyson DC08
A piece of paper sounds like that too!
A good time to give it a once over me thinks 😀
Hope you get it sorted,
quickwash :plug:
March 1, 2011 at 8:43 am #345806dames
Hi guys thanx for the replies .
To be honest I’m pretty sure it’s all clear , I’ll do it a again tho’ to check it all.
I had it open down to the motor yesterday to fiddle with the switch ( it’s worn ) I glued a piece of old credit card on top of it , jobs a good un 😀
Had it going while it was in bits and was fine But once I sat the filter and the case it sits in on it , the flap noise happened again. Is ther some sort of safety valve inside the motor casing?
I’ll wash the filter again and try that ( is there a shelf life for the sponge bit ? )
Job for today then :0)
Dames
March 1, 2011 at 8:56 am #345807kladave
You say you have washed the filter (blue sponge)but you have to wash the yellow outer as well.
March 13, 2011 at 10:52 am #345808dames
Hi , yes washed the yellow tray as well.
Was trying to get the cyclone apart ( its old so not worried about any warranty stuff ) , removed the screw under the handle and there are 2 obvious plastic clips holding it . Before I go bustin them :0) , whats the procedure to undo these , just push in and down?
EDIT: On closer inspection these clips would appear to be screws , question is how to get to them? :0)
I want to strip it down and completely wash the inside , is this possible?
Oh and why did you change the site? , this well laggy :0)
Cheers
Dames :0)
March 13, 2011 at 11:33 am #345809dames
All sorted stripped and cleaned ;0)
Dames
March 16, 2011 at 2:05 pm #345810dames
WOW , it’s like it’s brand new again lol. I even stripped down the spinning brush head attatchement and it works again after years. I won’t be using that one too often tho , it’s a bit of a ripper on the carpet I think.
Dames :0)
