E 1 error code on Smeg washer dryer WDI 147D-1
Home Forums Public Support Forums Help And Support Washing Machine Help Forum E 1 error code on Smeg washer dryer WDI 147D-1
  • #96484
    Jacko592
    Hi, Can any body help, I have checked the float trip switch under the drum and that seems ok.
    But the water intake hose has a bad kink in it, looks like it’s been run over with a forklift?
    I know that somehow? this hose has a water cutoff as well but not sure how it communicates with the washer as there is no connecting wire. Fitted a normal intake hose and still no water going into the machine and still E1 error code.
    New hose £126, any suggestions much appreciated
    #463550
    I think E1 on that model is a fill error but can’t find out for sure, however, I don’t know who’s telling you it’s that much for the hose as they’re having a laugh as you can see here:
    https://shop.ukwhitegoods.co.uk/758972630-smeg-dishwasher-aquastop-water-inlet-hose
    Check the valves are all okay as well, they’re built into the dispenser assembly that you can see here:
    https://shop.ukwhitegoods.co.uk/691170794-washing-machine-detergent-drawer-assembly
