E/lux EOC6690x oven glass smashed & no fan
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries E/lux EOC6690x oven glass smashed & no fan
  • #57754
    allan73
    Can anyone help me out on this I’m a bit stumped ?
    Customer has dropped something on door & smashed inner glass and now main fan does not run. I can’t see a contact switch for the fan that would be affected but there is what looks like a door lock for the self clean programme. F4 is also being displayed & sometimes f5 apparently ❓
    I can’t see the codes in the sticky at the top of this forum can anyone advise ❓
    The pnc is 944182614 if it helps.
    Thanks in advance Allan.
    #332164
    Re: E/lux EOC6690x oven glass smashed & no fan
    have not got info for this model apart from a crude wiring daig
    but earlier model EOC6630
    if the same
    F4 BROKEN SENSOR ALARM Problem with temperature sensor
    F5 TOO HIGH TEMPERATURE ALARM To high temperature
    have got tech info for earlier mod if you wanr but cant promise its the same if you want it let me know
    allan73
    Thanks for the info Dave, I still can’t work out how the inner glass being absent is stopping contact with the microswitch which seems to be built into the door lock and engages the main fan motor 😕
    The fault codes being produced are, I assume because the fan is not running causing the sensor to read an overheat.
    Allan
    #332166
    rogue_element
    F 0. No alarm audible signal. Replace the Electronic Board.
    F 1. Door not locking. Check Door Lock Mechanism.
    F 2. Door not unlocking. As above and the Control Thermostat.
    F 3. Self Check Error. Disconnect mains and reconnect after 5 minutes.
    F 4. Temp Sensor, o/c or s/c. Replace as necessary.
    F 5. Relay Contacts sticking. Replace Electronic Board.
    F 6. Power Board Temp too high. Check fan and duct position for correct airflow.
    F 7. Incorrect mains polarity. Check, reconnect and test.
    F 8. Power to Interface Connection. Replace Electronic Board.
    F 9. Microprocessor auto-resetting. Disconnect mains and reconnect after 5 minutes.
    #332167
    don
    Hope you don`t mind rogue_element but I copied the error codes to the known error codes thread. You never know it may help someone else in the future.
    Don
    #332168
    rogue_element
    no worrys don
    #332169
    allan73
    So after reading rogue_element’s description of the fault codes I’m wondering if there are other faults that aren’t caused by the broken glass on this oven.
    Maybe another one for the landfill ❓
