E/lux ESL6115 clicking?
  • #27759
    effzedarr
    Well weird this ,customer complains that m/c does nothing not even light up but makes a clicking/ticking noise from the control panel. Then after a day or two it will burst into life, do a couple of washes then back to playing up again. Went & had a quick check last nite, indeed no neons lit ,nothing but an ocassional ticking noise from the PCB area in the door!
    I’m getting mains to the PCB & the door switch is fine, on/off switch [on pcb] tests ok, only getting live to either side of dispencer coil, Im suspecting the PCB but would like another opinion, cheers guys..
    Regards Chris..
    #215501
    Re: E/lux ESL6115 clicking?
    PCB sounds good to me…… Transformers keep going down is a common one.
    effzedarr
    Cheers Chris, any reason why? Also is a replacement a straight swap i.e no config codes to do?
    #215503
    Plug and play…….
    Can’t find 6115 BTW – there is a 6225 – you hitting the wrong buttons? 😀
    EMW supply the t/x if that’s the problem.
    effzedarr
    Yep, right #, just found part on on TDS, 152 85 13-00/3.
    Thanx Chris, by the way hows it going?
    Regards Chris..
