e04 washing at 60c on Hoover Dynamic Next dxa 49w3/1-80
Home Forums Public Support Forums Help And Support Washing Machine Help Forum e04 washing at 60c on Hoover Dynamic Next dxa 49w3/1-80
  • #102338
    Starfield
    I’ve narrowed down the issue on my Hoover Dynamic Next dxa 49w3/1-80 to washing at 60c for prolonged periods. My family likes to wash at 60c for 1 hour (daily wash setting). Usually, it’ll get through the 1st wash, but the 2nd one will end in error e04. I check the pump every time and it’s clear. I usually wash at 40, but when doing a cotton towel at 60 for 2 hours (cotton setting), it ends in error e04. Could it be a temperature fuse issue? And no, I can’t convince them to wash at 40. I’m on an obscure forum looking for repairs on a washing machine. We have completely different mindsets.
    #488389
    sounds like the heater has an earth fault that gets worse as it gets hotter
    check the heater insulation resistance when its hot
    Starfield
    electrofix wrote: sounds like the heater has an earth fault that gets worse as it gets hotter
    Thanks. Finally decided to get off my arse and fix it.The element is 41039772, 1600w. Do I have to swap like for like, or would a 1900w work as well? Does it have to be the same height and the dip in the middle the same distance from the back? Also, “new” ones like these looks used https://www.ebay.co.uk/itm/373919668926? https://www.ebay.co.uk/itm/373919668926?. Is that normal?
    Edit: this looks like a 1:1 replacement: https://www.ebay.co.uk/itm/166263246443?
    #488391
    has to be correct element otherwise it wont control or work properly if at all
    its part of the transit brackets
    not needed now
    Starfield
    Seems to be sorted now, thanks for the help 🙂
    Washes like brand new
