E06 on Bosch WVT12840
  • #103497
    NotEinstein
    Hi.
    I’m getting an E06 on my mother’s Bosch washing machine.
    It washes and drains fine but won’t spin.
    For example, on ‘Drain and Spin’ it just counts down the time (making a noise) and comes up with the E06 at the end.
    It drains, the motor and belt must be OK. The door latch is a bit iffy but does lock and can’t be unlocked in use.
    What else could it be? Control board?
    Ewan
    #493394
    e06 is a drain fault according to the manual
    check filter first just in case
    if its draining ok then it could be a blocked pressure chamber
    this system along with the pressure switch detects water height
    find the pressure switch and remove the tube and blow down it to see if its clear
    warning do not blow in the switch itself
    NotEinstein
    Thanks – filter is OK – should have mentioned that.
    I’ll have a look at the pressure chamber.
